Control Rack on-off
benjotrash
hi,
there is an enabled outlet..you could use this..
benjotrash
Looks good. But this only works for a patch? . How can I Show the status of the rack?
Create a new rack and add a rack settings module, select the rack number and use the on outlet
benjotrash
But there is no on outlet. In the configuration window it is, but can not be connected...
sorry i dont understand..u need the status of a rack? if its enabled then its on, isnt it?
benjotrash
Where can I get that rack settings module you are using above? As you can see,in my rack settings there are less in and outlets....
benjotrash
Uh nooooo!! Sorry to waste your time 🤣... Didn't know that....
Thank you!!!
Thank you!!!
nay, is there a difference between on and enabled besides the outlet?nay-seven wrote:Create a new rack and add a rack settings module, select the rack number and use the on outlet
