Sending Program change
noise2sine
Unread post by noise2sine » 06 Apr 2019, 18:08
I’m looking for an idea for sending program change within an existing patch ? Any advice ?
Thank you
Unread post by oli_lab » 07 Apr 2019, 16:46
do you mean midi patch change or patch preset change ?
for midi patch change, use the midi create module
Unread post by nay-seven » 04 May 2019, 08:34
and for preset change add a patch setting module with a fader linked to current preset num inlet
noise2sine
Unread post by noise2sine » 04 May 2019, 17:04
I was wandering how can i send a program change message when recalling a preset inside a patch ?
I already have the module in my patch but i have to manually press the create button to send the message .
Thank you
Unread post by nay-seven » 04 May 2019, 17:41
a patch setting module/ outlet current preset num/has changed/inlet create of your MIDI module
