Video faster than normal
Garyool
Unread post by Garyool » 19 Mar 2019, 10:30
Hi
I have a problem with video player, the player plays my video faster than the normal speed and i didn't touch the speed bouton.
The video format is .mp4 or .mov and it's the same result.
Does anyone have an idea ?
thanks
x.iso
Unread post by x.iso » 19 Mar 2019, 14:11
maybe sample rate of included audio doesn't match audio engine setting?
Unread post by cmodica » 19 Mar 2019, 16:12
I had the same problem a few months ago. I didn't solve it but i should worked. So i synchronize Hollyhock and Cubase. Compose the sound with HH and Cubase and read the video with the Cubase video player.
There wasn't any sound in the video that i try to play with HH. It was a H264 .mov video.
I am interesting if you find the reason why it plays faster.
Unread post by grego mondo » 19 Mar 2019, 16:23
frame rate video (in setup/video) ?
Garyool
Unread post by Garyool » 19 Mar 2019, 19:08
My Fps = 24
I try with one of provided video like "forest", i have the same problem ...
i haven't audio on my video
Unread post by senso » 21 Mar 2019, 08:08
humm, It should not.
Or maybe only few frames faster.
For a test, open the same video in vlc et usine and try to start them at the same time (almost).
ps:you can also adjust the video speed on the player itself it can help.
Unread post by cmodica » 28 Mar 2019, 11:37
i have a problem with the video player. The FPS is not stable ? there is some variation between 22 and 25 FPS. I play the video on a 2nd screen thru a video projector.
I don't have any external clock or SMPTE generator. Only my laptop MacBook Pro retina, Mac OS 10.12
Unread post by senso » 28 Mar 2019, 15:46
try to set the audio engine speed to the fastest as you can in the setup.
for example 200fps.
this will improve the global video engine speed and so the precision.
your 25fps videos will stay at 25fst, but the engine will respond faster.
Unread post by cmodica » 28 Mar 2019, 17:55
Ok
Thank you very much.
Unread post by cmodica » 28 Mar 2019, 18:00
Ok. Thank you. It works !!!
Unread post by senso » 28 Mar 2019, 18:17
Be careful, it increases the CPU load...
x.iso
Unread post by x.iso » 28 Mar 2019, 20:14
If I'm not mistaken, videos are decoded in same way they will with any video player by default, meaning if dGPU decoding is enabled for certain codecs, it should also offload to dGPU in Usine?
Unread post by senso » 28 Mar 2019, 20:30
yes we use the ffmpeg library to decode videos. This library uses GPU if needed independently the settings of Usine.
Chafff
Unread post by Chafff » 08 Apr 2019, 15:36
Hello I have the same trouble here
my video is played 2time faster than the orginial one, I've tried to setup the audio engine at 300 but nothing happend.
when I play the Usine demo video they seems ok for the speed but it lagg.
thank you for your answer
Unread post by senso » 09 Apr 2019, 09:20
I think that it comes from the codec of the video. Can you try to convert it into another format ?
Chafff
Unread post by Chafff » 12 Apr 2019, 10:13
I convert it in AVI uncomressed the speed seems ok but it lag a bit (even though my footage is in 720/480)
I'm running on a windows 10 familly 16G ram I7-4720HQ Nvidia Geforce GTX960
I've tryed with the demo video file and it still lag a bit
Unread post by senso » 16 Apr 2019, 21:44
The video engine totally rewritten in the next major release. Much more powerful and efficient.
Chafff
Unread post by Chafff » 17 Apr 2019, 11:47
Great :)
by major release you mean HH4 or 3.x ?
Users browsing this forum: Google [Bot] and 28 guests
