I'm trying to do a patch where a 8x8 matrix data is the "remote" of a 16x16 matrix audio. This allowed me to activate stereo send/returns by clicking only one cell.
But I have sometimes cells that stay on when they should be off and I can't solve it. Maybe I didn't patch in an academic way.
If someone could have a look at, that would be great. Here is the patch http://www.sensomusic.org/forums/upload ... matrix.pat
Matrix remote
Hi had a look at your patch, before further investigation, wouldn't it be simpler to use 2 8x8 audio matrix, one for left channel and one for right channel ?
- x.iso
Yeah, I though there's definitely a way simpler way to do it, and that's it. patch cells out to both L and R 8x8 audio matrix and that's it.
Thank you for your posts. Yes indeed that's a simpler way to do this.
But as I'm a new user of Usine I'd also like to know which part of my patch is not efficient.
So if you can give me some advices I'llbe very pleased.
