The conductor
noise2sine
Unread post by noise2sine » 12 Feb 2019, 19:17
i used to use the conductor a lot in Usine V5 , does anyone know how can i use something in order to save global snapshots of settings from different patches and being able to switch between different settings during live performance ?
Thanks !
Unread post by nay-seven » 12 Feb 2019, 21:44
have you try to use the preset panel of your workspace ?
Unread post by nay-seven » 13 Feb 2019, 08:01
right click in an empty part of your workspace/settings panel/show preset panel
noise2sine
Unread post by noise2sine » 22 Apr 2019, 10:52
Is it possbile to move up or down a preset in order to re arrange the list ?
Unread post by nay-seven » 22 Apr 2019, 11:56
Not currently, but yes in HH4
noise2sine
Unread post by noise2sine » 22 Apr 2019, 21:38
Great ! When that version will be available ?
Unread post by nay-seven » 24 Apr 2019, 12:43
New users, pro users or simply if you update your license, you'll join the beta team ;-)
We're working on, but a delay of 48 h is possible to share the folder.
Users browsing this forum: No registered users and 375 guests
