Show Airwindows real parameter values
emiliano
Unread post by emiliano » 08 Dec 2018, 18:47
I would like to be able to show the real parameter values of the GUI-less Airwindows VST plugins. I know I can get create faders with values from 0 to 1 t control the parameters. However, "real" values (for example cutoff frequency, or even stepped "console type") are obviously coded inside the plugins (in some cases), as is revealed when using Reaper. How can I do the same thing in Usine?
Unread post by nay-seven » 11 Dec 2018, 17:13
you can set a fader with real values and use a change scale module to enter you VST inlet with a 0-1 range this way:
x.iso
Unread post by x.iso » 11 Dec 2018, 18:10
I think the question was if it was possible to get actual value range from GUI-less VST itself, and that's something to add in suggestions forum.
emiliano
Unread post by emiliano » 15 Dec 2018, 12:21
Thank you for your replies.
As said by X.Iso, I am looking for a proper way to get the real parameters values and names from these Airwindows plugins. For example some parameters have three discrete possible values : Neve, SSL and API.
I understand that it is not possible for now.
Unread post by SylvainT » 15 Dec 2018, 22:31
I thing Nay-Seven gave you the right solution.
I thing VST plug-ins always allows 0-1 inlet and not real values
emiliano
Unread post by emiliano » 16 Dec 2018, 10:53
Thank you Sylvain.
I think VST plugins can send back information to the DAW about the real parameters names and values (not 0-1). Here is how a VST Airwindows plugin appears in Reaper, with three different positions of the parameters. I was wondering if it was possible in Usine, too.
Unread post by nay-seven » 16 Dec 2018, 11:34
As said before,Usine can't do that by default, but here a patch to illustrate what i mean, replace the subpatch by your vst
Download
emiliano
Unread post by emiliano » 16 Dec 2018, 15:04
Thank you Nay-Seven. You patch shows how to implement text in the parameter values, so that will help me !
Unread post by nay-seven » 16 Dec 2018, 15:39
cool
just forgot a / module where b=2 to have the correct values for this one
Users browsing this forum: No registered users and 125 guests
