I'm actually building a loop pedal for a dance performer, based on Echoplexx.
Each layer goes into a surround panner SIMPLE.
I'm using 4 speakers, so each layer turns around with its own speed, or randomly.
Everything's ok so far.
I only need to be able to toggle between 2 behaviors for the REC button.
The first one (the one that works actually):
Press REC to record the BASE layer.
Press REC to stop it.
Then press REC to start the layer 1
Then press REC to stop layer 1,
So on.......
The second behavior I need to do is :
-Press REC to record the Base layer.
-Then press REC to stop the BASE Layer AND start the First Layer at the same time.
-After that, no need to press again the REC button for the other layer. Every layer is recording one after the other according to the BASE layer's duration.
How could I achieve that ?
Here is the link for the rack as it is now.
http://www.sensomusic.org/forums/upload ... akers.rack
thanks a lot for your help.
Best
Christophe Rault
"Rec mode " in Echoplexx
Christophe Rault
What you mean is :
1st trigger = rec base
2nd trigger = stop base rec and start layer 1 rec (after the lenght of base, stop layer 1 rec and start rec for layer 2, after the lenght of base, stop layer 2 rec and start rec for layer 3, ...)
What I would do is build a brand new patch with
5 samplers
a rec switch (master)
from your rec switch :
0 to 1 - set on - rec base
1 to 0 - set off - rec base
/ set on - rec layer 2
/ start - count ms of the lenght of the base
finished trigger - set off - rec layer 2
/ set on - rec layer 3
finished trigger - set off - rec layer 3
/ set on - rec layer 4
something like this
hope it helps ...
What you mean is :
5 samplers
something like this
hope it helps ...
Christophe Rault
Thanks a lot !
I'll have a try. I'll tell you how it goes.
Best
Christophe
Best
Christophe
Réalisateur radio, metteur en ondes, création sonore, archerie asiatique et vit sur une péniche.
Christophe Rault
Everything is going well with the patch.
Thanks a lot !
I've made it with 10 loopers and four audio output going in 2 surround panner.
I've also implemented a fixed duration, chosen prior to recording (5 sec each layers for example). So we have to press a button only once (useful in live situation where no tempo is needed).
The only problem so far is a digital clic happening on each looping point. I'm trying to find a solution. But do you think of something that could help ?
here is the rack as it is now.
http://www.sensomusic.org/forums/upload ... 20GUI.rack
Thanks again to all.
Best
C.
Thanks a lot !
Best
C.
You can use an ADSR audio module to create small fade in and fade out to avoid clics.
Christophe Rault
Yes, it seems to works alright ! Thanks.
Still working on it right now.
I'll will let you know later on when it works well.
I have to look for bugs now.
Best
Christophe
Best
Christophe
Users browsing this forum: No registered users and 129 guests
