NOundo 0.343 release
joffo78
Unread post by joffo78 » 26 Oct 2018, 10:34
NOundo is here ! http://www.sensomusic.org/downloadaddon ... elease.zip
A powerfull looper machine with à lot of fonctions.
Enjoy ita
Unread post by gwennaelle » 23 Nov 2018, 16:48
Noundo seems nice but with Usine Hollyhock 3.0, I can't open it because "Noundo has been created by an earlier version of Usine. Usine cannot load it. Please update it." (Noundo a été créé par une version antérieure d'usine. Usine ne peut le charger. Veuillez le mettre à jour.)
What is the good version of Usine tu use it? Thks
joffo78
Unread post by joffo78 » 24 Nov 2018, 00:08
Hello.normally you can open it with 3.175 untel 3.180
Unread post by senso » 24 Nov 2018, 08:50
You can click 'ok', Usine will load the wkp anyway.
Unread post by gwennaelle » 25 Nov 2018, 18:10
Ok ! Today it's working with the 3.0 181 version (and doesn't work with alpha version).. thanks !
I'd like tu use it with Lemur on Ipad.
The connection between Lemur Editor and Lemur on Ipad is ok but I don't success to connect Lemur to Usine.
I didn't find in the Noundo guide, in the Lemur User Guide or in the Lemur IAE guide. How do you do?
Thanks again
joffo78
Unread post by joffo78 » 25 Nov 2018, 21:41
You need to install lemur daemon to send midi information to usine. 8 virtuals deamon midi port will be created.
Unread post by gwennaelle » 29 Nov 2018, 19:56
Yes, it's ok now.
Verifying the connection, I notice a strange behavior when in the launchpad I click on a pad :
- 1st clic : the pad on Ipad and the one on Noundo are red,
- 2nd clic : the pad on Ipad is black and the one in Noundo is red,
- 3d clic : the pad on Ipad is red and the one in Noundo is black,
- 4d clic : the pad on Ipad and the one in Noundo are black.
How could we control controllers behavior?
How to activate the input tracks?
Questions at beginning... I will spend time on it especially to play with the launchpad.
Thanks for this proposition !
joffo78
Unread post by joffo78 » 29 Nov 2018, 20:13
Did you activate the launchpad switch on the matrix ?
Unread post by gwennaelle » 22 Jan 2019, 20:07
Yes, with Lemur and when the button is activate, it's ok. But with the pad of the APC Key 25, the buttons of Noundo doesn't correspond to the ones of the APC. And it seems impossible to make midi links. Or is there another thing? Thanks.
Unread post by nay-seven » 25 Jan 2019, 15:09
Quite normal cause APC don't have the same note number sheme as the Launchpad
There's 2 scripts in the addon named launchpad to APC and APC to launchpad , you'll need to insert them in the midi in / out device to correct this i suppose ?
Joffo can you confirm ?
joffo78
Unread post by joffo78 » 25 Jan 2019, 16:59
Not sur but i suppose it works
Unread post by nay-seven » 25 Jan 2019, 18:56
ok, so i've made a quick test, works better but not correctly
the first 4 row of the matrix answer correctly when you press a pad ON, but no feedback when you switch Off, normal cause the color code of the APC is different
I'm afraid Noundo is made for launchpad, or it will need some work to also answer to an APC
amok
Unread post by amok » 26 Apr 2020, 12:49
i should be a Gold Member for try it ?
Unread post by nay-seven » 26 Apr 2020, 13:05
?? Gold member don't exist anymore since several years now.
simply download the zip file in the first post and load the .wkp from Usine ?
