The question is simple. How does HH3 takes advantage multicore processing?. In other words, How it distributes the workload through the different cores of a CPu, in this case an AMD Ryzen 3 2200g ( 3.5 Ghz. 4 cores).
Thanks.
HH multicore preformance
I would assume that any threads that are not in use are used by modules when needed, so it should be avoiding queues as much as possible. but with VST's it only depends on developer of said VST.
There is info about the threading in the PDF manual.
I think each rack is a separate thread at the very least. But it probably uses threads more than this,
since you can select the number of threads to use.
Maybe its the OS (e.g Windows) that spreads the theads across the cores.
I'm sure Senso could give us more details.
Perhaps the CPU monitor could be changed to show information about core usage ?
Simon.
Simon.
Find more info in the manual here:
cpu-consumption
cpu-consumption
Users browsing this forum: No registered users and 271 guests
