Reorder presets
Ander
Unread post by Ander » 06 Oct 2018, 02:37
How can I change the order of saved presets on Preset Manager?
Unread post by nay-seven » 22 Oct 2018, 10:39
Currently there's no easy way, but a quick workaround is to create new ones, copy them in the good order and delete the first old ones.
joffo78
Unread post by joffo78 » 22 Oct 2018, 13:58
intersting question !
Unread post by SylvainT » 22 Oct 2018, 14:00
Request in discussion with Senso for upcomming update, maybe for HH4. But you had to be patient
Ander
Unread post by Ander » 12 Dec 2018, 04:11
Is a very slow way to change the presets order... but is the only way!!!
nay-seven wrote:Currently there's no easy way, but a quick workaround is to create new ones, copy them in the good order and delete the first old ones.
Drag and drop to reorder presets in the list view is the easiest way to do it, just like the way that we can reorder collapsed racks.
Is this feature hard to program and implement?
I think that maybe a kind of customized presets manager can be created with draggable content list.
SylvainT wrote:Request in discussion with Senso for upcomming update, maybe for HH4. But you had to be patient
Users browsing this forum: Google [Bot] and 23 guests
