IB status?
ahonoe
Unread post by ahonoe » 22 Aug 2018, 18:50
Can anyone tell me if there is a way to query if HH is showing the interface builder screen? (My application toggles between workspace and IB modes but is having trouble remembering which mode it was last in when I load my workspace.)
Thanks.
Regards,
Scott
Unread post by nay-seven » 22 Aug 2018, 19:04
There an option in the workspace settings panel /startup/show IB
And you'll find the same option in the corresponding module ( interface control/workspace settings)
ahonoe
Unread post by ahonoe » 22 Aug 2018, 20:10
Thanks Nay however this is an input only. Is there some way to check if HH is currently showing the IB?
Regards,
Scott
Unread post by nay-seven » 22 Aug 2018, 20:42
you're right there's no output, maybe a switch, visible in top header and connected this way ?
or use the same shortcut than IB mode ( CTRL/CMD+I) on a switch , also visible in top header ?
ahonoe
Unread post by ahonoe » 22 Aug 2018, 20:49
Thanks again, Nay.
Regards,
Scott
Users browsing this forum: Google [Bot] and 170 guests
