help me to make a script for my patch
joffo78
Unread post by joffo78 » 15 Aug 2018, 23:55
Hi
I made a big patch to communicate with a launchpad in HH
here
It make absolutly what i want it should do.
But in my opinion it take too much cpu because of the redundancy of task.
So i wonder if is not possible to make some script to make it lighter.
I'm sure it's not complicated at all but i'm not coder.
Thanks a lot and hope this patch would be usefull for the community
JF
Unread post by oli_lab » 16 Aug 2018, 15:54
hi, [s]is there a reason why, on the launchpad, the first cell of the second row is sending note #16 instead of #8 ? (same for consecutive rows actually)
would be more straight forward to interface if each cells sends consecutive note on.[/s]
is it this launchpad ? : https://d2xhy469pqj8rc.cloudfront.net/s ... -s-prm.pdf
in that case, why don't you use the round button on the right ?
I did this : File uploaded: http://www.sensomusic.org/forums/upload ... %20mod.pat
input goes thru a script, output is "monophonic"
joffo78
Unread post by joffo78 » 17 Aug 2018, 01:28
Hi Oli.
Thank you for your patch. I tried it . It doesn't work whith my launchpad (mini)
It work only when i select a row by clicking but not with the launchpad directly.
It dosen't work too when i recall a preset.
Sorry.
Unread post by oli_lab » 17 Aug 2018, 12:52
oh, tha'st interesting !
I don't have a launchpad, so I had to go for the user manual, maybe I didn't look at the good one.
send me the exact manual of your own mini launchpad and I try to fix the script
joffo78
Unread post by joffo78 » 18 Aug 2018, 00:21
hi.
Thank you for interseting on this subject.
here
is the manual
regard.
JF
Unread post by oli_lab » 18 Aug 2018, 02:27
I used the array inside your patch to get the correct notes :
first row : 0 1 2 3 4 5 6 7
second row : 16 >> 23
third row : 32 >> 39
4th row : 48 >> 55
5th row : 64 >> 71
6th row : 80 >>87
7th row : 96 >> 103
8th row : 112 >> 119
when I send those notes from a keyboard on channel 1, the cells on the matrix are set alight accorddingly.
File uploaded: http://www.sensomusic.org/forums/upload ... od%20B.pat
Unread post by nay-seven » 18 Aug 2018, 17:14
test here with Launchpad mini too
if i press a pad on the LP, it's ok, the matrix react correctly, but the Launchpad itself don't light at all ( if i check the midi out of the patch, it send only 1 note ON, always the same ( normal , it's connected to last clic cell as code 1)
i f i fill all the matrix with the mouse, the LP react, but, here the color error i have:
hope this help
joffo78
Unread post by joffo78 » 18 Aug 2018, 17:36
Yes. The color différence is caused because on the hh matrix i don't know if it's possible to choose for each cell is own color.
It was possible on usine 5.80 (and before) but not on this new module. Unfortunatly
joffo78
Unread post by joffo78 » 18 Aug 2018, 19:37
Not sure it's possible to do that with the actual module
Unread post by 23fx23 » 18 Aug 2018, 21:24
..for me clearly the true colors arrays in controls were better...often miss them..
