Special Dispatcher
Ariajazz
Unread post by Ariajazz » 26 Jun 2018, 06:19
Hi all. Sorry but I haven't found a way to do it... I need a sort of dispatcher module that sends "1" value as a switch to the selected output and "0" to the rest of outputs. I know how to do it with switches grouped but in this case the selection is made by a set of numbers 1 to 16, the way a dispatcher does. I hope you have gotten the idea.
x.iso
Unread post by x.iso » 26 Jun 2018, 13:47
could be simplified with a single 'sequenced switch' module though, depending on what's the goal.
Unread post by 23fx23 » 26 Jun 2018, 18:56
or an empty array of wanted size , followed by a set array element value set to 1
Ariajazz
Unread post by Ariajazz » 27 Jun 2018, 03:40
Thanks all for replying. Joffo's patch worked with some modifications I did. I'm not good working with arrays so the other alternatives were not useful. Thanks again.
Users browsing this forum: Bing [Bot] and 23 guests
