usine hollyhock 3.0.171 update
Announcements
Unread post by nay-seven » 16 May 2018, 14:09
[large]3.0.171[/large]
improvements
- New sdk 7.01.006
- New recreateParam procedure
- New ptBitwise parameter's type
bugs
- Inlets text settings don't work properly
Unread post by sm_jamieson » 25 May 2018, 11:12
what does ptBitwise do ?
Unread post by nay-seven » 25 May 2018, 11:21
You'll find some Bitwise math modules in the browser /math and here the wikipedia description
Unread post by oli_lab » 25 May 2018, 16:16
I did some bitwise math module a few while age and I used float inputs : should I use those bitwise inputs instead ? are they just 32bit integer inputs ?
joffo78
Unread post by joffo78 » 25 May 2018, 17:03
When a major update ? :D
Unread post by sm_jamieson » 25 May 2018, 20:16
oli_lab wrote:I did some bitwise math module a few while age and I used float inputs : should I use those bitwise inputs instead ? are they just 32bit integer inputs ?
Well we have been wanting 32 bit integer inputs for a while, would be cool it we have them now !
Unread post by senso » 26 May 2018, 11:42
@oli_lab
Yes now you should recompile your modules with ptBitwise parameters for a full compatibility with Usine's bitwise type.
