NyquistEq VST from Magnus and usine
martignasse
Unread post by martignasse » 21 Mar 2008, 16:01
hy all,
I use this VST plug a lot, it's perfect for live, but i noticed a strange behiavor :
When i tweak the band adjustment by mouse, in the plugin GUI, the sound change is audible, but the values isn't changed in the usine panel (visible when the plug module is selected, in the patch).
The question is : is it a usine probleme or the plug fault ?
I absolutly need to have this working, because the plug control is assigned to my BCR2000, and don't take aount of the change made by mouse.
And more than that, it seem's to be responsable of a "Switch timer buffer error" in usine sometime.
Hope someone can help.
runagate
Unread post by runagate » 21 Mar 2008, 17:42
I seem to recall that it works this way in FL, also, but I'll check when I get home. By no means does every VST have it's parameters properly published for use by the host program.
martignasse
Unread post by martignasse » 21 Mar 2008, 22:41
...I discovered than when i tweak the 'program' combo box, it make the usine panel refresh....
But can't be automatised...grrrrrrr....
Unread post by senso » 22 Mar 2008, 12:11
I'll take a look.
probably a refresh problem in Usine
