Hi. Any body knows this product : http://www.amazon.com/Elgato-Stream-Dec ... TWXG1AQ5C2
I'd like to know if it's possible to change icons with the context.
Elgato stream deck
As I understand, it is only possible to configure in a special app, not on the fly.
Yes but it seems possible To affect one button to open à new page. It would be possible to create an arborescence with a root page
Caractéristiques principales :
15 touches LCD personnalisables
Icônes de touches configurables
Jusqu'Ã 210 actions
Simple à utiliser
Enrichissez vos gameplays
Interface : Câble USB 2.0
Dimensions : 118 x 84 x 21 mm
Poids : 190 g
Compatibilité : Windows 10 (64 bits), Mac OS 10.11 et versions suivantes
Jusqu'Ã 210 actions
Simple à utiliser
Poids : 190 g
Users browsing this forum: No registered users and 53 guests
