It's frustrating when I want to move a control, and the png for it is not found.
Then I have to go searching around in my files to locate it. A few times I haven't been able to find it, and have had to re-create the control, esp. if it's been several years.....
A small thing, but it seems like you should be able to copy and paste within the same wkp without losing data....
keep pngs during copy paste
Also, I haven't found a way to remove assigned image, it only asks to find another, no option to remove.
Dont remember for hh but in older versions that was ctrl+click on path to remove the image
yes, that still works....
Thanks! At least that's solved for me.
Images are stored in the patch itself in what we call the 'image pool'. And on old patches the original location is lost.
I'll see how I can improve this point.
