Since my previous topic was not correctly named.....
Seems like a logical move that would cut down on download bandwidth for Senso, and speed up downloading and installing of new versions, in light of HH's rapid release schedule.
cheers,
-e
renamed: HH Sample Content as separate download?
Agree here too . Could be some kind of popup at install quest if wanna dowload and install extra libraries maybe?
If there's going to be popup, it should provide option to select sample library folder first, then ask if update is necessary. Usually samples are already installed, for those who just update, or those who use their own sample library as well. So it would make sense for Usine to install samples in existing user library, or just use that library without downloading anything.
I suppose Senso will answer more later, but remember demo workspaces need library samples, presets for groove machines patch need library samples, convolution reverb need library samples and more ...
It's an old suggestion not so easy to implement.
I'll think about that+++
