Please check this routine:
have an external midi controller connected
link it to a rack's input volume
bring the volume down via the midi controller
save the workspace's preset
disconnect the midi controller
reload the preset
move the fader via the mouse
even if the fader moves and is at correct position ( 0 dB) there is no signal getting into the rack.
the VU meter in the input shows no incoming signal
when I connect the midicontroller again I get the input control going, the signal shows its activity on the VU meter. Accordingly it is actually present at the output.
this behavior is happening since many releases, can't say when it started happening
Midi commands being retained without showing
hello,
tested on last version, PC and Mac, can't reproduce this.
What do you have in your rack ?
have you test this from an fresh empty workspace and with only an Fx patch in the rack, let say the first one, the delay analog.
is it possible to send you a short video?
yes, you can upload it on a dropbox or equivalent if you think it can be useful
Users browsing this forum: No registered users and 1414 guests
