If I make my list buttons tall enough to select with a touch screen, the text size is
HUGE AND SUPER BOLD
and then every item nds to be abrv or thrs not engh rm for it, unls you mke the lst
REEEAAALLLYYY WWWWWIIIIIIIIDDDDDEEEE TTTTOOOOOOOOO
If I had this feature, I wouldn't have to use matrixes for every little thing.....
cheers,
-e
Items text font scale in listButtons object....
Same feature in the combobox would also be welcome..... can't replace them with a matrix, without a popup too....
Generally, I would like to have text wrap option for UI objects.
in the v162, I'll add 'items font size factor' in the settings in order to change the font size.
Users browsing this forum: Google [Bot] and 11 guests
