Better support for VSTs not found
Unread post by woodslanding » 13 Feb 2018, 00:24
Since we know every vst will have:
Audio ins and outs
Midi ins and outs
Parameters and Param Names in and out
etc.
Can we have a 'not found' vst that shows meaningful connections for ins an outs?
I do a lot of work on wkps on my laptop, which does not have most of my vsts installed. It would be nice to be able to wire to a 'ghost vst' which will be correctly recalled when I move the patch back to my other computer...... I realize wiring to specific param nums is impractical (some of my vsts have upwards of 5k parameters) but at least audio, midi, and params arrays could work.....
This would also be helpful for addons, etc.... Maybe it could be an actual 'Simplest Possible Vst' that is included in the build, and automatically substituted if the real vst is not available....
For that matter, I suppose it could even have 9999 parameters-- and a gui with a textfield for param number, and a knob for value...... ;)
gurulogic
Unread post by gurulogic » 13 Feb 2018, 11:03
Good suggestion! +1
Unread post by sm_jamieson » 13 Feb 2018, 11:41
Very good idea.
Unread post by oli_lab » 13 Feb 2018, 11:50
+1
x.iso
Unread post by x.iso » 13 Feb 2018, 15:07
+1
Unread post by senso » 26 Feb 2018, 15:49
humm...the problem is that in the general case vst's can have 0,1,2,16 audio in or out.
and it seems to be too complex for what it does.
you can use a simple volume module or create a fake vst with a script, then just replace it with a drop?
Unread post by woodslanding » 27 Feb 2018, 22:15
But any time you open a patch, can't HH determine which ins and outputs were originally cabled to on the vst?
... if the idea is just to have a meaningful view of existing cabling.
But yeah, maybe not worth the trouble.
