switch triggering a button
Ariajazz
Unread post by Ariajazz » 18 Jan 2018, 07:17
Hi all. I need a way to send a button message with a switch. In other words, trigger a button with a switch. I've tried everything I know and can imagine but don't get any satisfactory result.
Thanks.
gurulogic
Unread post by gurulogic » 18 Jan 2018, 07:27
try the from 1 to 0 or from 0 to 1 modules in patching
Unread post by oli_lab » 18 Jan 2018, 12:39
or the "has changed" module if you want the button activated each time the switch changes state
Ariajazz
Unread post by Ariajazz » 18 Feb 2018, 05:03
THANK FOR REPLYING. It worked. What about the opposite - Trigger a switch by pressing of a button?, in other words: turn on a switch with a button
Unread post by 23fx23 » 18 Feb 2018, 05:28
button -> toggle if wanna alernate. or connect to a switch 'set on' if wanna only set it on, never off
Ariajazz
Unread post by Ariajazz » 21 Feb 2018, 02:46
Ok guys sorry to tell you this but the "from 0 to 1 and/or 1 to 0" did not work for triggering a button with a switch, Any other ideas?. I'm stuck. Thanks all.
Unread post by nay-seven » 21 Feb 2018, 09:27
works perfectly, can you be more precise ?
Ariajazz
Unread post by Ariajazz » 21 Feb 2018, 15:06
Thanks Nay-seven for replying. I have a function that employs a milisecond counter, as far as I know the counter's START is activated by a button not a switch. I need to be able to start it by a switch, that's why I thought that triggering a button with the press of the switch could work but I don't find a way to do so.
Ariajazz
Unread post by Ariajazz » 22 Feb 2018, 21:54
I NEED HELP WITH THIS PLEASE
Unread post by nay-seven » 22 Feb 2018, 22:00
Don't shout, share your patch...
Ariajazz
Unread post by Ariajazz » 23 Feb 2018, 00:26
Sorry for the inconvenience, I reviewed my work and I was patching erroneously 1 to 0 and 0 to 1 DO WORK. I appologize. Thanks to all.
Unread post by nay-seven » 23 Feb 2018, 08:36
good news !
