I think there's a need for ability to edit default plugin wrapper template or even make more than one. so we would also need a template manager of some sort.
Add-on section can also get separate pluginUI category for user shared and approved templates or patches made as wrappers for specific plugins, that would make things easier for everyone and especially beginners.
Plugin wrapper templates
1) not sure to understand, you can create and add personal templates in the /Config/Templates/ folder.
Just copy and modify any /Resources/Templates file and put them in /Config/Templates/
2) we plan to update the site, especially the addons page and its organization structure.
Ok, I'll try that and see if that's exactly what I meant.
Hi x.iso,
If you need help with the templates for the plugins let me know.
I did one for the VST Learn plugin option and can help if needed.
I've got several others I use that I have not released either for examples if needed.
Template Manager - Already suggested...I created a clunky one I'll see if I can find...but:
+1 for a Template Manger with HH
-s
-s
So these are scripts. Well, I can see that it's not easy to just make a patch as template, since there's need for scripted action (like adding desired plugin somewhere in the patch).
Users browsing this forum: No registered users and 132 guests
