Usine Hollyhock 3.0.144 update
Announcements
Unread post by nay-seven » 22 Oct 2017, 21:57
[large]3.0.144[/large]
improvements
- Improved ArtNet test in the setup
- Implementation of node and sub-net settings in ArtNet engine
- MIDI-split (multi split) module
- Drop-file-mode option in the sampler
- Improved light-direct-dmx and light-direct-artnet modules
- Vertical-lock mode on sequenced-steps and array-display modules
- Clear-drop-file-name inlet in modules
fixed bugs
- Possible issues if 2 webcam are connected with the same name
- Control positions can be lost when a wkp is saved in IB view
- Sometime, racks are reloaded with wrong outputs settings
- Array-expand doesn't work as expected
- Sequenced-points modules is not created properly
3.0.143
3.0.142
3.0.141
intermediate versions
secretkillerofnames
Unread post by secretkillerofnames » 23 Oct 2017, 12:13
Love your work!
Install is nearly half the size of previous .app even after updating from previous install.
1.13GB to 663MB.
Did you do something to optimise or is something fishy going on?
:D
x.iso
Unread post by x.iso » 23 Oct 2017, 13:33
Nice update. But I don't get it about the picture included, seems like plugin UI integrated into patch, but there's no such feature yet.
Unread post by nay-seven » 23 Oct 2017, 14:02
Thanks, and no, the vst is only next to the patch, sorry for the possible false hope :)
ericb
Unread post by ericb » 27 Oct 2017, 08:59
I have download it, but here it is impossible to open the application.
I work with Maverick, is it the reason of the issue?
Regards
E
Unread post by nay-seven » 27 Oct 2017, 09:41
Hello Ericb,
maybe you have similar issue with Sierra users, have you check the installation page ?
ericb
Unread post by ericb » 27 Oct 2017, 11:19
Thank you Nay-seven
It appears that it was my third-party expansion software wich cause the issue.
Regards
Eric
Unread post by nay-seven » 27 Oct 2017, 12:03
good news !
Users browsing this forum: No registered users and 187 guests
