Strange issue with HH3 when patching
Unread post by cmodica » 18 Oct 2017, 08:40
Hi all.
I'm starting to explore H3. It is very cool and uselfull.
I have a strange issue when i want to delete one or more module in the patch. Generaly it works fine. But suddenly, it is impossible to delete. The bar space didn't turn on the play button etc ... everything works but it is like the keyboard is deconnected ....
I should quit and start again to restore.
It happens 2 times in the afternoon.
(MAC OS 10.12.6 - Hollyhock 3.0.140 - Macbook Pro Retina 2012)
Unread post by nay-seven » 18 Oct 2017, 08:51
no error message ?
if this happen several times again, can you copy your file LogUsine.log please ?
Unread post by cmodica » 18 Oct 2017, 09:13
No error message.
The next time it happens i quit and copy the log file.
Unread post by cmodica » 18 Oct 2017, 11:46
It happens this morning again after 1 hour. Everythink work fine. The connection between the soft and the keyboard is ok exept the Backspace with didn't delete anythink. :/
It works again after restart Hollyhock.
This is the log file
Unread post by nay-seven » 18 Oct 2017, 12:15
Unread post by cmodica » 23 Oct 2017, 17:02
now it happens all the time. I can't work on a patch ! it is very boring ... :o
It is impossible to delete a module or a wire until quit and restart ! And after a few minutes it is the same ... quit and restart ... etc.
So i work with HH2. :mad:
It is the same thing after the new update to HH 3.0.144.
Nay, did you find something in the log file ?
Unread post by nay-seven » 23 Oct 2017, 17:09
No, anything really useful,
You use some VST, can you try a new start with a new workspace without VST and test if you have same behavior please ?
Unread post by cmodica » 23 Oct 2017, 17:33
Since Half an hour it works fine. :/
I will try to test but you should be right. It should be a VST problem ... I will try to find witch one.
Unread post by nay-seven » 23 Oct 2017, 19:16
ok,
good news in a way for us, i know it's not easy about VST, but remember Sierra is quiet new (and still in beta btw) so several VST can have issues
Unread post by cmodica » 23 Oct 2017, 19:21
Siera is not in Beta but High Siera is still in beta. i din't upgrade the OS to the last version.
It is a good news for you, but some VST are very usefull for me ... :/
Don't worry, i love to change my abitudes. ;)
Unread post by nay-seven » 23 Oct 2017, 19:25
For me it's still in beta, for Usine i've join apple beta test team and Sierra is still updated regularly.
Unread post by cmodica » 23 Oct 2017, 20:57
Ok. I understand.
Thank you
crackle
Unread post by crackle » 14 Dec 2017, 04:57
first post.
Users browsing this forum: No registered users and 699 guests
