Update 3.55 (Spectral Edition)
Announcements
Unread post by senso » 12 Feb 2008, 09:57
Intermediate release 3.55 (Spectral Edition)
Improvements
- new set of Spectral and FFT audio manipulation
See examples in the demo folder:
Spectral Gate
Spectral Expand/Compress
Spectral Analysis
Spectral Shift Frequency
Spectral Filter
Spectral Clip
- new set of array manipulation modules
- new Direct to Disk engine more efficient, with a new buffering system.
Fixed bugs
- keyboard conflicts with Battery3 plug-in
- next-previous doesn't work properly in loop mode of the sampler module
Usine VST version will arrive in march...
Unread post by cmodica » 12 Feb 2008, 13:42
Wonderfull !!! I will try it, i am so exited to test the new FFT tools ....
Thank you
goyya76
Unread post by goyya76 » 12 Feb 2008, 14:08
Just downladed twicw but....the file seems broken! you know, when you try to decompress it, a pop up "pops up" saying it's damaged....
Ciao,
Goyya :)
stanlea
Unread post by stanlea » 12 Feb 2008, 14:17
Yes, the archive is corrupt.
You know my name (look up the number)
Unread post by senso » 12 Feb 2008, 14:45
yes zip files are corrupted.
I upload the 3.55b now.
Sorry...
stanlea
Unread post by stanlea » 12 Feb 2008, 21:10
Now the zip uncompresses well, but the Usine exe file crashes.
runagate
Unread post by runagate » 12 Feb 2008, 21:50
WOW!
I love this!
Unread post by bsork » 12 Feb 2008, 22:14
Me too! No chrashes, and everything seems to be working ok.
...if only I understood anything of the FFT/Spectral stuff... Good that someone else does.
Thanks, Olivier!
stanlea
Unread post by stanlea » 12 Feb 2008, 23:05
I insist : this version crashes on my PC, the app crashes, closes but a ghost process remains in my task manager. Could it be dual core related ?
Unread post by senso » 13 Feb 2008, 00:00
Normally in this version there is no change in the audio engine, but only few modules added. But in computer domain we never know...
Can you send me the log file?
stanlea
Unread post by stanlea » 13 Feb 2008, 07:24
OK but now it seems there's a problem with my config. Old versions also crash, so it's not the new version. So I'll post no more here, sorry for the thrills. Anyway, I'll send you the log.
Unread post by senso » 13 Feb 2008, 09:48
good news for me, but not for you!
stanlea
Unread post by stanlea » 13 Feb 2008, 12:56
A reboot solved the problem. Probably a shared ddl with a program that had crashed.
multiphone
Unread post by multiphone » 15 Feb 2008, 09:46
To busy to check the new version of usine.
But i'ts marvelous ! You develops much faster than I do music... i'ts fantastic.
I check that today.
Thanks for your job.
H.
HB
Lines / Points / Squares
http://www.hervebirolini.com/
