I am using drop filename for my UI interactions. It would be super useful to have a "reset drop file name" input on all objects that support drop file names. I imagine this working like the "clear" trigger currently does on list objects.
Thanks.
Reset drop file name trigger
- senso
You already can clear the field with a [ctrl+click] but I can add a reset button.
will be implemented in 3.0.144
- senso
yes, an inlet to reset it from an external source
