Well this is prob fairly obvious thing i must miss/forget, but how does man quit the full screen mode?
if i press the icon on the toolbar i go in fullscreen mode, ok, but clicking back doesn't revert here, am i missing something?
quit fullscreen mode
I have had the same problem, it seems to affect only certain systems so apparently is hard to solve the problem. Maybe v1.4 will provide an adequate method. From another thread: "In the version 140 you'll find a full screen inlet in the usine master module"
Ah ok thanks i had a doubt. ok i check the inlet thhing, map to a key or something
On which OS/Version ?
And have you try CTRL+F ? (by default , or create your own Key learn)
I had the same problem (Windows 10 system), but it's solved with 139 version and hardware acceleration apparently.
EDIT: oh, nevermind, just tried it and it still happens.
Ah ok thx guys .Nay win 10 hh3 latest 139 hw accell (on nvidia) . Tested f11 didnt thought about ctrl f or map the button, ill give a shot tonight but yeah i remember seeing a thread about v140 might have to wait this one maybe
Users browsing this forum: No registered users and 104 guests
