I was just curious if there were any already made Clocking Modules for use in the SDK, or any code snippets to share?
I don't want to be redundant, I'd rather evolve things and keep a standard rather than many duplicate modules of the same type.
-s
Any Example Clocking Modules Available?
do you mean clock for oscillators or clock as for VST's ?
Just general like a sync clock, position clock base...etc.. or square oscillator...haha
I have a synchro control that I use all the time that senso made and I'd like to actually do a sequencer clock controller.
-s
-s
if syncing to usine musical events best is prob to use ppQ, smpte or other ms datas given in the vsttime info strucure as source depending on what wanna build
http://www.sensomusic.org/sdkdoc/html/s ... _info.html
for clocks sequencer/lfo ect personally i usually use multipliers and fmods of PPQ, ie getting a clock 2x faster: fmod(PPQ * 2, nb_of wanted_beats)
otherwise if no synced basically count blocs like in bloc counter scripts, each bloc a counter increments in process procedure, a callback or event reset it.
then eventually multiply by something like bloc_duration global variable. or another way is check timeMs at a start of event, then while process run TimeMs - start-time gives the current ellapsed time. in fact there are many diiferent way depending on final taget goal, not sure a general template fits
Users browsing this forum: No registered users and 3 guests
