Changing time signature
noise2sine
Unread post by noise2sine » 19 Aug 2017, 09:20
In the old days i was using the conductor ( USINE V5) in order to change the time signature.The preset in the conductor allowed me to recall settings and sample and time signature.
for example preset 1 : is 4/4
preset 2 : is 7/16
How can i reproduce this in Hollyhock ?
thank you :)
Unread post by nay-seven » 19 Aug 2017, 10:29
- Create a patch and add a list module and a master synchro module
- link the comma text outlet of the list module to the list of bars inlet of the master synchro
- create your list of bars in the list module, add presets to this patch
Note you can also create a list of bars directly in the settings panel of the master synchro ( main interface)
noise2sine
Unread post by noise2sine » 19 Aug 2017, 13:37
Thank you i will try !
noise2sine
Unread post by noise2sine » 19 Aug 2017, 16:10
Sorry but i didn't manage to do what you said : i have a list box and the master sync module. The comma text outlet of the list box is conected to the bar list of the synch module . But i didn't find a way to create the list :(
What am i missing ?
thank you
Unread post by nay-seven » 19 Aug 2017, 16:58
yes, my fault, my solution create a bar list, can't provide presets
use the text outlet
here the patch:
Download
noise2sine
Unread post by noise2sine » 19 Aug 2017, 22:49
it's working perfectly , thank you very much :)
Users browsing this forum: No registered users and 120 guests
