I have a problem with the RC51 when I hit the record button to stop recording and start looping the loop starts in time, but when it reaches the end of the sample player, just a half a second before the loop ends the sound stops and then it loop again in time. It doesn't lose the time, it doesn0t add a tiny slice of time into the loop, it just stoles the last 0.5 second of what I played from the loop. Why does this happen? I'm so frustrated, I want to get things working properly without much hassle..
Anybody knows this issue? Could somebody suggest me something?
looper 51 problem
I think it just that you didn't recorded long enough
No I'm sure Oli, I pressed again rec button on the metronome click. Something else is happening. Also, why the RC51 cannot unsync with the Usine master tempo? If I want to use as the boss RC300 for instance where the length of all loops are set by the first (or master) one, I just simply can't..Or maybe I missed something?
I had also discovered similar loop sync problems and have been well assured that the synchro has been improved for HH3 and this problem no longer an issue. Soon I hope...!
never use synchronized loop but did a quick and dirty looper from scratch :
File uploaded: http://www.sensomusic.com/forums/upload ... looper.pat
hope that'll help
hope that'll help
Users browsing this forum: No registered users and 452 guests
