Reproduce an analogique tape recorder behaviour
I don't know if it's a suggestion improvement or if we can do that by patching.
I'd like reproduce an analog tape behaviour with a sampler.
The goal is when i change the pitch or the speed when i'm recording it don't modify the signal input on the recording. So when i be back on the original speed or pitch m'y recording is alterated.
Joffo
Joffo
+1
maybe a patch workaround be sampling the pitch animation when the recoring occurs (ie to automation, or step/line/array data to keep aility of further offseting), then play that automation back with inversed function once rec is done, so that if when recing a pitch was set at -12, on play it will be +12 and play twice faster like HW would
It would affect all the take that are overdubed
Joffo78 is right.
it need to be an altogether different module than the sampler.
with speed control on record as well as on play.
I'm not sure I'm quite following what the objective here is, and I may be totally off track, but what comes come to mind for speed control on record as well as play is to use a local sync to manipulate the record and playback speed and also using two or more samplers to have separate manipulations for different layers.
eh ! I'm working on it !
[s]I made this "varispeed" thing that work on play AND record
so far I implemented in the new version of the Hydrogene V4 module
only for Win64 so far[/s]
more to come soonish : multitap delay with varispeed, looper...
in fact it is not working properly
I managed to half the sampling speed and thus to get the recording played an octave up
that should be fun for a looper
for the varispeed (continuous variation of sampling speed) it is more complicated !
will need resampling...still trying.
Users browsing this forum: Bing [Bot] and 137 guests
