Where are all the Addons?
Vas
Unread post by Vas » 05 Apr 2017, 18:07
I found the top 100 Hollyhock and top 100 Usine Pro 5.x and older
http://www.sensomusic.org/addons.php
where is the complete list of HH addons/modules etc
where is the complete list of Usine Pro 5.x and older addons/modules etc.
I hope the the lists are separate as I understand they are not compatible.
tried "addons" non the boom of the page.
http://www.sensomusic.org/addons/
got Forbidden notice.
Windows 10-64bit, i9, 32GB RAM, Studio One 5, Reaper 6, FL Studio 20, Komplete 11,
Unread post by nay-seven » 05 Apr 2017, 18:21
you have found the Usine 5 addons, all are there
HH addons are also included in Usine, press the update from internet button in the browser/addon tab
Vas
Unread post by Vas » 05 Apr 2017, 19:25
nay-seven wrote:you have found the Usine 5 addons, all are there
There are exactly 100 Usine 5 addons and no more?
I found the top 100 Hollyhock and top 100 Usine 5.
Two separate lists selected from the drop down menu.
So the 200 total addons on both lists can be used with HH and Usne 5?
here it states "350 addons"
http://www.sensomusic.org/index.html
Is there a list of the 350?
Can I assume that all of the 350 can be used in both HH and Usine5?
Found the 400 Modoules
http://www.sensomusic.org/wiki3/doku.ph ... al:modules
These are both for Hollyhock and the Usine Pro 5.x and older. Correct?
Clearly I am overlooking something.
Unread post by nay-seven » 05 Apr 2017, 19:43
There's maybe around 350 addons (usine5+HH) , addons for Usine 5 works only with Usine 5, HH was totally rewritten to be compatible with Mac. Consider them as 2 different software's.
Btw, Addons are made mainly by users and some are really old, and all users don't update their work following Usine version's, so you will maybe encounter incompatibilities. Sometimes it's only a graphic issue and you can rebuilt them easily.
But you can understand we can't assure maintenance on our side, so you'll need to ask to the author of the addon if needed
Vas
Unread post by Vas » 05 Apr 2017, 21:39
nay-seven,
Thanks for the super fast reply.
Usine 5 addons only work with Usine 5.
Hollyhock addons only work with Hollyhock.
Correct?
There are two lists of 100 addons
100 for Usine 5
and
100 for Hollyhock
here
there are a total of around 350 addons.
if you subtract the 200 there are 150 left.
Are these for Usine 5 or for Hollyhock?
Where can these 150 addons be found?
Or are you saying that they are the old
users addons with possible issues and
perhaps best to avoid?
Item two:
Found the 400 Modules
http://www.sensomusic.org/wiki3/doku.ph … al:modules
are these for both Hollyhock and Usine 5?
Please clarify these issue for me.
Don't mean to be a pest.
Unread post by nay-seven » 05 Apr 2017, 22:18
ok, so
yes, i didn't notice but yes i suppose there a bug with the php page and you can see only 100 addons for each version, but again, better way for HH is to use the browser.
i don't know the exact number of addons, it's change often and we also have deleted some which are too old (oldest ones are from 2011 now) so maybe there's less than 350 now , but is it so important ? old ones will not work anyway ;-)
now if you want test, you'll see that under some conditions (no scripts, no user modules, etc..) some addons from v5 can be opened in HH
about modules, it's a different things,except some users modules provided by users on the forum or as addons, you can't download them, it's internal to Usine, when you install Usine ( v5 or HH) they will be integrated and you can't use them anywhere else and are not compatible between versions
Vas
Unread post by Vas » 05 Apr 2017, 22:49
nay-seven wrote:ok, so
"better way for HH is to use the browser."
Please include the link to the browser.
Is there also a Usine browser?
"maybe there's less than 350 now , but is it so important ? old ones will not work anyway"
Thanks for the clarification. Don't need to see addons that do not work.
Got it. The 400 modules are part of HH and part of Usine.
They are not individually downloadable. Thanks
I am interested in both the HH and the Usine addons/modules/libraries/etc.
I suppose I need to get to use HH and Usine to better understand them and the addons etc.
But I will wait for HH3 and then invest time to learn them.
Users browsing this forum: No registered users and 93 guests
