Good morning.
In which cases makes it the most sense to use Quick Links instead of regular cables
in terms of saving CPU Cycles?
Thanks in advance,
tL.
In which cases makes it the most sense to use Quick Links?
The thing is they add latency like buses do, and for that reason I avoid them.
Simon.
Simon.
well, there are places where a bloc of latency doesn't matter. Anything involving updating the display--opening a popup window, changing the name or visibility of a control, etc. Don't send audio or midi through them, unless it's just setting the midi channel or resetting the cc number of a control or something like that....
But they can clean up your patches! And if you have a big wkp with a lot of busses, they will reduce your CPU.
Be aware, they work only within a patch, not between patches, even if they are in the same rack.
Thanks for clarification.woodslanding wrote:Anything involving updating the display--opening a popup window, changing the name or visibility of a control, etc. Don't send audio or midi through them, unless it's just setting the midi channel or resetting the cc number of a control or something like that....
Perfect, that's what I wanted to know before I spend a lot of time optimizing my racks (quite a lot of them)woodslanding wrote:And if you have a big wkp with a lot of busses, they will reduce your CPU.
because I usually have pretty big wkp's and I was hoping that these help with the CPU strain.
Thanks again, I knew this one though..woodslanding wrote:Be aware, they work only within a patch, not between patches, even if they are in the same rack.
Best,
tL.
Users browsing this forum: Google [Bot] and 17 guests
