Website/Forum suggestion
gron
Unread post by gron » 13 Mar 2017, 04:04
I've been digging around Usine for a couple of weeks in between work and a newborn (which is to say not nearly as much as I'd like) but so far I'm incredibly impressed with what I see. Still quite overwhelmed and have way more questions than answers right now but will save them till my education builds a little further out of respect!
I doubt you will see this as a top priority but as someone who is currently bouncing between Usine and the forum regularly, often in lowlight situations, it is blinding to switch to the website with a white background after being on the dark background of Usine. I find that I'm constantly turning my brightness up and down as I switch back and forth. I figured I'd let you know.
Keep up the great work! :)
gron
Unread post by gron » 13 Mar 2017, 04:40
Well, I just found a fix for my own situation. A chrome extension (one of many apparently) that will invert the colours on the site. Works a treat.
https://chrome.google.com/webstore/deta ... ated?hl=en
Hope this saves some eyeballs!
r.erorr
Unread post by r.erorr » 18 Mar 2017, 13:39
Usine internal help, references and module info would be nice.
Unread post by senso » 22 Mar 2017, 22:36
hello,
not a mater of priority, we always try to do our best !
I think that for text readability white is often better?
But I understand your point of view, I'll see if I can change css, but not so easy.
Users browsing this forum: No registered users and 107 guests
