Enttec open dmx usb on MAC OSX with Usine
BatKam
Unread post by BatKam » 16 Jan 2017, 22:27
I'm having a big issue : I just bought an Enttec open dmx usb and it doesn't work in Usine. In the configuration pannel of the MAC, it recognizes it as FT232R USB UART. But Usine can't detect it...
Any suggestions ?
It would be so nice!
Thanks in advance
BatKam
Usine Hollyhock 84a, OSX 10.9.5
Unread post by nay-seven » 22 Jan 2017, 10:39
Enttec drivers issue. Solved by email answer
For those who encounter the same, check this Enttec page, they have a specific tool to update their drivers and solve this.
hgermain
Unread post by hgermain » 12 Feb 2018, 19:10
Hello, i have the same issue, but i can't find on the enttec website the tool you are talking about...
thanks!
H
Unread post by oli_lab » 12 Feb 2018, 21:12
I strongly recommend the artnet DMX king series !
hgermain
Unread post by hgermain » 13 Feb 2018, 10:24
thanks for the recommandation! but i already have the enttec :-/
hgermain
Unread post by hgermain » 14 Feb 2018, 11:08
Oli LAb, why do you prefer the artnet DMX king series?
as it stil doesn't work with enttec, i might consider buying one...
thanks
Unread post by oli_lab » 14 Feb 2018, 13:29
hgermain wrote:Oli LAb, why do you prefer the artnet DMX king series?
thanks
I prefer Ethernet more than USB !
with Artnet, your computer is connected on a LAN as is the DMXKing.
you can hot plug everything, if there is a loss of power every thing get recconected automatically.
hgermain
Unread post by hgermain » 14 Feb 2018, 16:28
thanks Lococol i give it a try!
Users browsing this forum: No registered users and 205 guests
