The auotmap program does not work with Usine.
It does work with Ableton, Sonar, Bitwig, ... many others.
It may have something to do with "ReWire" compatibility?
Novation Automap
That's weird, I had automap working with the remote zero controller a year back.
At least it should have nothing to do with ReWire.
Novation Automap has been a flaky tool in my toolbox for quite some time. I've followed it recently and the only thing I can even recommend that is anything worth of note is an OSC-based third party plugin for Lightroom. Look up Device Templates for Paddy.
Perhaps I'll dust mine off and see if there is any way I can make it sing in Usine...
I use an old Nocturn controller with automap and Usine on Mac, works fine here ?
Scraninger, do you mean that the automap with vsts feature is not working in Usine ? I do not use the automap vsts feature so I can't say if working but otherwise the mapping software/remote zero controller etc works fine for me with Usine on windows 7 64 bit.
