There is the 'load patch' module that will load a patch to rack 3, slot 2, for instance, but I cannot find an example of the syntax to script this, as every example seems to set target patch to sender patch.....
I did look at the console when I used the module, but there is no IML for creating the patch itself, just for creating the object inside it.
Any tips welcomed.
thanks and happy holidays!
-eric
IML: what if target patch is NOT sender patch
My initial thought is to pre-create a template/dummy patch and either use a "load patch" or a "load module (subpatch)".
did that, and no IML.... I made a patch with a single 0to1 module, and loaded it from the loadPatch module. All I get in the console is one line:
create module TpgFrom_0_To_1 219
no create patch at all.
Well, I found a good workaround, using a combination of scripting and the load patch module.
I'd also like to have a script to clear patches, though, so if anybody knows how to do that....
Once again, I can load an empty or near-empty patch, so there is a workaround.
well, now I'd like to load a subpatch of a different patch, so hoping there is some way to specify the target patch. I'll try another forum search....
Users browsing this forum: Bing [Bot] and 78 guests
