Multi Channel Audio Wire / Bus
gurulogic
Unread post by gurulogic » 25 May 2016, 19:34
Often I would find it very useful if I could send multiple channels of audio down a single wire or bus. Maybe possible some time?
Unread post by senso » 15 Jun 2016, 13:00
implemented,
within a single bus but multi wires in the next major release.
gurulogic
Unread post by gurulogic » 16 Jun 2016, 00:29
Good news, Thanks!
Unread post by woodslanding » 07 Dec 2016, 23:52
ahhhh, this might help with the variable numbers of outputs with different vsts, as I mentioned in my vst module dll loading request?
The vst module could have a single (stereo or not?) audio in and out, and the user could mult/de-mult them as needed to get access to the extra pins without risking orphaning cables?
Unread post by sm_jamieson » 09 Dec 2016, 03:30
A couple of ideas about the buses and wires:
1. Can the new multi-wire bus contain wires going in both directions ? If would be great it it could since often you want feedback or 2-way communication.
2. The way of treating everything as signals on the wires is very useful for lots of things. But it would be useful to have a new type of "message" wire that is single-shot and is not mixed up with the "has changed" stuff. The message would sit on the wire for 1 bloc, like what we do manually when sending midi and have to clear the array after a bloc to stop repeat messages. The new message wire would have no problem if the same message is sent again - where "has changed" can get in the way, but it would still be picked up in the parameter callback so onProcess would not have to poll, which is wasteful of CPU.
The midi bus could even be changed to work this way so we would no longer have to clear the midi parameter after a bloc, but just send a midi "message".
Simon.
Unread post by sm_jamieson » 18 Jul 2017, 22:42
Is the
"a single bus but multi wires in the next major release."
in HH3 ? I cannot find any reference to it in the User Interface or the manual.
gurulogic
Unread post by gurulogic » 19 Jul 2017, 01:42
You are right, I do not see any reference for the modules description in the manual, however on my OS (Windows 7) When I drop a get or set audio bus into a patch window there is a menu to choose number of audio channels. Do you not see this?
Unread post by nay-seven » 19 Jul 2017, 09:15
the module page say "Sends multi-channel AUDIO flows to an internal Bus." what description do you need more ?
Unread post by sm_jamieson » 19 Jul 2017, 12:49
OK, thanks for putting me on the right track.
Somehow I missed that it was only for audio signals. Anyway will be very useful for sending stereo signals around.
dontogueli
Unread post by dontogueli » 25 Jul 2017, 14:42
gurulogic wrote:Often I would find it very useful if I could send multiple channels of audio down a single wire or bus. Maybe possible some time?
It's really ok but I have made something wrong:
[right]If the first time has result fine working with the Usine video lessons now I have not the good thing:[/right]
Shift and drop on module out _Sampler-out1 -shift/drop- Audio output I _
I think that I have changed something in the configuration.
In the path config or in general config.
I restart Usine, open a new empty workspace. New sample player- new loop inside.
Same result: no multiwire.
I have tried some combinations:
Hold the shift button before hold and drag with the mouse. Unhold (¿?my english...) the shift button before unhold the mouse...all this with all combinations, permutations, I sing an old Indian song while the process....nothing
I am on Usine 3.0.1.134----W7 64 bit i7 4770 3.40GHz---Focusrite Scarlett 6i6---Quneo and Akai MPK240(Akai disabled)
Sorry for my limited English
Thank you for all your help.
And thanks Usine for its impeccable and imprescindible work
Unread post by senso » 20 Sep 2017, 18:21
it's [ctrl+shift] + drop not [shift]
Users browsing this forum: No registered users and 103 guests
