VST1 & VST2.4 & VST3 & VSTi Compatibility with Usine Hollyhock 2?????
SuggarBearr
Hello and welcome suggarbearr,
VSTt 1 are really old now, if you still have one, maybe will work but generally with no graphic interface, VST 2 and VSTi works with Usine, VST 3 not yet.
Remember Usine is a free download, so you can quickly know if your plug ins works
As an option for vst3 loading , if you use a wrapper / chainer such as Bluecat Patchwork in Usine, it is possible to load vst3 and more.
Yes
SuggarBearr
One more question I got these effects that just say VST is the regular VST compatible????
Users browsing this forum: No registered users and 374 guests
