Usine old version VST ?
I was looking in another forum for a vsti that can have multiple audio tracks in it and sync play to the (Windows) host.
"The old VST version of Usine can do that.
http://www.sensomusic.org/download.php
Usine is not what I'd call 'simple' though, rather a quite deep program, but it has a sequencer module where you can put audiofiles playing in sync with the host."
How do I get this download this vst, is there a price, a demo version ?
Thanks.
Thanks.
Hi there,
i thought that Usine 5 Stage - which is also available as VST and VSTi - is actually free. Maybe they revoked that access, i dunno, 'cos i've always been a "pro" user. Nay should chime in any minute to shed some light on this situation.
Best
Best
I tried to Download
Usine Stage VST-i 5.80 020b.dll
Usine Stage VST 5.80 020b.dll
but they were greyed out and it said "You must be a Silver member to download the file. Please login or buy a license"
I found Free version VST links over the internet
http://www.sensomusic.com/download/
but I get:
Forbidden
You don't have permission to access /download/ on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
but I get:
Forbidden
The link per se is working, with the proper status, that is( i'm platinum) . There is no "silver member account" anymore, only pro or non-pro/edu. As mentioned above, nay-seven usually handles these things. I reckon the whole user system will be somewhat updated with the launch of the new version.
Yes, these olds versions are free with all licenses (PRO and EDU)
So to get the VST/i to play wav files n sync to the Host I need:
Get a new license of Usine for 69€ ?
I've send you a dropbox link on your email with the dll,
test it and if this is useful for you and want discover more, you'll buy a license later
Thank you much appreciated, will try it out !
Users browsing this forum: No registered users and 104 guests
