Usine old version VST ?
BobMuso
Unread post by BobMuso » 28 Sep 2016, 23:03
I was looking in another forum for a vsti that can have multiple audio tracks in it and sync play to the (Windows) host.
"The old VST version of Usine can do that.
http://www.sensomusic.org/download.php
Usine is not what I'd call 'simple' though, rather a quite deep program, but it has a sequencer module where you can put audiofiles playing in sync with the host."
How do I get this download this vst, is there a price, a demo version ?
Thanks.
iococoi
Unread post by iococoi » 29 Sep 2016, 08:01
Hi there,
i thought that Usine 5 Stage - which is also available as VST and VSTi - is actually free. Maybe they revoked that access, i dunno, 'cos i've always been a "pro" user. Nay should chime in any minute to shed some light on this situation.
Best
BobMuso
Unread post by BobMuso » 29 Sep 2016, 11:56
I tried to Download
Usine Stage VST-i 5.80 020b.dll
Usine Stage VST 5.80 020b.dll
but they were greyed out and it said "You must be a Silver member to download the file. Please login or buy a license"
BobMuso
Unread post by BobMuso » 29 Sep 2016, 12:18
I found Free version VST links over the internet
http://www.sensomusic.com/download/
but I get:
Forbidden
You don't have permission to access /download/ on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
iococoi
Unread post by iococoi » 29 Sep 2016, 13:09
The link per se is working, with the proper status, that is( i'm platinum) . There is no "silver member account" anymore, only pro or non-pro/edu. As mentioned above, nay-seven usually handles these things. I reckon the whole user system will be somewhat updated with the launch of the new version.
Unread post by nay-seven » 29 Sep 2016, 13:18
Yes, these olds versions are free with all licenses (PRO and EDU)
BobMuso
Unread post by BobMuso » 29 Sep 2016, 14:41
So to get the VST/i to play wav files n sync to the Host I need:
Get a new license of Usine for 69€ ?
Unread post by nay-seven » 29 Sep 2016, 15:53
I've send you a dropbox link on your email with the dll,
test it and if this is useful for you and want discover more, you'll buy a license later
BobMuso
Unread post by BobMuso » 29 Sep 2016, 20:46
Thank you much appreciated, will try it out !
Users browsing this forum: Bing [Bot] and 329 guests
