issue loading vst/au on mac
Hi everyone,
I'm very new to Usine but while I was testing I tried to use external plugins and I was stopped by an error.
First, Usine had troubles to recognize my plugins but it eventually find them. But now I can't use any of them (vst and au) and I get an error 015 every time (sometimes followed by a little window with some more errors saying "create procedure failed").
I'm on a 32bits mac but I've always been able to use my plugins in every audio software so I don't understand what seems to be the problem here.
Some help would be greatly appreciated.
Thanks in advance.
Thanks in advance.
Hello and welcome saynom,
Here are the E015 error definitions
Impossible to load the AU or VST plugin
* not compatible with you system version
* you try to open a 32bits plug into a Usine 64bits, or inverse
* the plugin doesn’t exists any more in your system
Hope this help
Hope this help
Yep, I saw that, but none of these cases concern me.nay-seven wrote:Hello and welcome saynom,
Hope this help
ok, can you please give me on which OSX you are and example of plug ins you try to run ?
I'm on 10.6.8 and my plugins are some basic au(disto/delay/EQ/etc) and GRM tools. They all work fine everywhere else.nay-seven wrote:ok, can you please give me on which OSX you are and example of plug ins you try to run ?
ok, so i'm afraid i can't test cause, as said on our compatibility page , 10.6 is no longer supported.
but maybe someone else here have still this OS ?
Darn it, I didn't see that... Sensomusic also do that? Every companies drop support on 10.6.8, I thought naively that you weren't one of them... That's sad.
If someone else has an idea to fix that it would still be appreciated of course.
Anyway, thanks for your replies Nay-Seven.
Users browsing this forum: No registered users and 316 guests
