Does Hollyhock have midi and audio output?
Vas
Unread post by Vas » 06 Jul 2016, 21:15
Since I cannot use Hollyhock as a VST in my DAW’s I am considering using it as a stand-alone virtual instrument and midi controller as I already have 23” multitouch screen. So I hope that HH has a midi and audio out which will be routed to my DAW be it Cubase, Sonar, Reaper or FL Studio.
I know very little about HH but the modular environment which can host the 400 built-in modules, 350 addons, Ultra flexible library with 100 ready to use audio FX and generators, the Creative extended library and VST fx and VSTi looks very inviting.
Windows 10-64bit, i9, 32GB RAM, Studio One 5, Reaper 6, FL Studio 20, Komplete 11,
shawnb
Unread post by shawnb » 06 Jul 2016, 21:47
If I understand your whole question correctly, the answer is Yes and No...
Yes, HH2 has audio & MIDI output.
No, HH2 will not natively allow you to take your audio & MIDI output & route it to another DAW.
To route MIDI from HH2 to another DAW is easy with a product such as LoopBe.
To route audio from HH2 to another DAW would require Rewire support or similar, but HH2 does not yet support Rewire.
However, there are other threads on the forum here where folks explore alternatives to Rewire, such as VSTforx & Regen:
http://www.sensomusic.org/forums/viewtopic.php?id=4498
Nothing is impossible, you just might need to find the right tools to get it done!
Vas
Unread post by Vas » 06 Jul 2016, 22:39
Wow!
shawnb thanks for the quick reply.
Ok the midi part is an easy one. Just use LoopBe1 or LoopMidi.
I wonder if asio4all can be used to route the audio from HH2 to a DAW.
Might this work?
5 Free Virtual Audio Cable Software
http://www.dxzone.com/5-free-virtual-au ... -software/
and more on Google: audio output input virtual cable windows
https://www.google.com/webhp?sourceid=c ... le+windows
This is something I will not do right now but am very interested to know if possible.
Thanks to let me know that it is possible!
Getting closer to pulling the trigger on HH2!
But if HH2 besides being a stand-alone it was also a VST or VSTi I would already purchased it.
shawnb
Unread post by shawnb » 07 Jul 2016, 04:34
Yes, those are along the lines of what you're looking for!
I've heard good things about Jack.
I've never used any of these tools myself, so I can't vouch for them personally.
CREDO
Unread post by CREDO » 07 Jul 2016, 18:37
ReaStream (free ReaPlugs) has worked for me.
http://www.reaper.fm/reaplugs/#tour
Unread post by nay-seven » 07 Jul 2016, 18:53
Don't forget the hardware solution, a good sound-card with several inputs/outputs is also a good solution.
Users browsing this forum: No registered users and 337 guests
