Is it possible to automate or trigger in real time the "reverse" option for each sound in the new MIDI sampler ? I can edit this option manually in the sound list, but I would like to affect a MIDI learn for all of them in the same sampler.
thanks
reverse on midi sampler
Sadly, there no individual or array inlet for this option
don't know if it can suit your needs , but an idea could be to create a new bank and double each sound
then set each second one to reverse mode
save the bank
Now a simple Midi transform module before the sampler with a switch (0 / 1) on the pitch inlet will do the job ?
save the bank
thanks Nay-Seven,
A 2d reversed bank is a good idea, but my banks are very large (about 150 sounds) and evole on each new concert. It would be difficult to manage. May be in HH3 ?
Ok, i understand,
so you can maybe add this to the suggestions forum ?
