OSC between Synapse (with Kinect) & Usine
BatKam
Unread post by BatKam » 10 Mar 2016, 13:46
Hi there,
I'm trying to work with Kinect-via-Synapse receiving data from Synapse (here is the website of the developer I use the non MAX/MSP user version).
My main issue is that I can't receive datas from Kinect-via-Synapse into Usine. It works with OSC.
Here is are screenshots :
From Synapse : http://www.sensomusic.com/forums/upload ... enshot.jpg (the skeleton has been detected)
From Kinect via Synapse : http://www.sensomusic.com/forums/upload ... se%201.jpg
http://www.sensomusic.com/forums/upload ... se%202.jpg
From Usine : (network setup) http://www.sensomusic.com/forums/upload ... 0usine.jpg
(patch usine) http://www.sensomusic.com/forums/upload ... othing.jpg You can notice usine sees a data flow input
Do you have any suggestions to make this working with usine ?
Thanks in advance ! :)
Unread post by nay-seven » 28 Apr 2016, 16:48
sorry for this late response
Not easy to answer because many parameters are involved , not only Usine
2 things:
the address /head seems short for me, are you sure it's ok ?
you don't need to activate share option, and moreover don't use the same port for both
Unread post by gwennaelle » 08 May 2016, 12:02
Hello Batkam
I have the same interest to link Usine and Kinect. I used it with Ableton and Synapse but now would to use it with Usine.
If you came to the workshop at Canal 93 in may, we met there...
I'd like to continue the discussion. Could we?
Thank you !
Gwen
BatKam
Unread post by BatKam » 09 May 2016, 16:20
Hello Nay-seven & Gwennaelle,
Actually I went to the last workshop at Canal 93 and we found out with Olivier the issue. The version of usine I was using (2.0 083b) didn't see the osc message as osc one. It was UDP one. The bug seems fixed on the last version (84a?).
I will maybe be at the next workshop Gwaennaelle so see you :)
