save patch order in preset
CREDO
Unread post by CREDO » 08 Mar 2016, 21:06
I use Usine mostly as an intricate midi/guitar effect chain. If the patch order of a rack could be changed dynamically it would cut WAY down on the number of patches to load and organize.
Unread post by sm_jamieson » 11 Mar 2016, 11:21
You need to use a patchbay (probably such a module in the add-ons) and wire the in / outs of each patch into that. Then use the patchbay to wire up the patches in the order you want. Then use midi learn / preset manager to store different configurations.
Building patch reordering into Usine may not be ideal since its kind of against the idea of wiring things up. Re-wiring patches can be done usine IML commands, but its slow and not intended to be done dynamically as part of live situation.
Unread post by sm_jamieson » 11 Mar 2016, 11:29
I've put a question on the patching forum about a suitable patchbay module:
http://www.sensomusic.org/forums/viewtopic.php?id=5356
Unread post by senso » 11 Mar 2016, 15:01
Not easy in the general case, but I'm thinking about a way to change patches orders dynamically.
