I am writing a user module that has some functionality that I can only program for PC.
I know little about MAC, OSX, etc. Unless anyone else can help with an approach for MAC, this functionality will only be available on the PC. What pre-processor directives (ifdef, etc) should I put around this code so it would be excluded in a MAC compilation ?
I am using Visual Studio - I guess the MAC compilation would be an X code project ?
compiling for MAC
sm_jamieson,
I used to try to stay on top of compiling OS X versions of user plugs. It's a big effort though, and sadly I fell behind.
There are a few options for automatic compilation on various platforms. Maybe one of those could offer a more robust solution.
Either way, you could add your code to https://github.com/ab5tract/hollyhock-grove via a pull request (sorry, can't give all the details for using git/Github, but they have a nice GUI client to get you going, and google has tons of information on the subject).
Then I can at least compile the version you decide to release.
@ceasless : I'm getting crazy with this github !
can I send you my new sources via we transfer before the definitive nervous breakdown ?:P
I try to cross compile for mac OSX but it is to geeky for me and now I have no more time as I have to concentrate on my new musical set !
can you help ?
many thanks.
can you help ?
many thanks.
oli_lab, no worries you can transfer to me however you want!
do you reckon the MAC version of visual studio will work "out of the box", I may try to borrow a MAC from a friend...
Users browsing this forum: No registered users and 78 guests
