Touch OSC and Pitch Bend
Zoltan
Unread post by Zoltan » 27 Jan 2016, 17:42
Code: Select all
Nooob Incoming
I set up a rack with a piano roll with a vet (sylenth1)
i put a fader for the pitchbend in usine, using default value @0,5 and auto reset.
I create a pitch bend fader in touch osc but the pitchbend don't auto-reset.
I set up my lan connection and think that everything is ok.
Can someone help me :)
Zoltan
Zoltan
Unread post by 23fx23 » 27 Jan 2016, 20:30
hi zoltan ;) so if well understand you got an osc recive module from touch osc connected to the fader,
for testing you probably have to temp unwire this have and osc send module to same adress out of fader with according port number.
if so moving the fader in usine should move the fader on touch osc, and when you relase mouse should reset in touch osc.
the problem is i think the auto reset depends on mouse relase of usine fader. when you control from touch osc, usine don't get this info of 'mouse relased' from the phone,it just gets the float fader actual value, so it can't really know it has to auto reset. This can be possible if you get 2 infos from touch osc, the float fader value itself , and a 'is pressed/touch" info,
don't have touch osc here so can't test sadly.
Zoltan
Unread post by Zoltan » 27 Jan 2016, 21:26
I didn't saw who answer lol hi Fx23 :)
i see the problem with the 2 infos.
It's sad because i can see in Touch Osc that an info is incoming but not recognized.
Zoltan
Users browsing this forum: Google [Bot] and 16 guests
