Can't see the patch
skraninger
I created a "default" patch with a VST (Synthmaster) and can't see any of the patch elements (in the patch window).
The patch is working as expected, just not showing anyting in the patch window/pane.
All of the other VST patches are showing up as expected.
Maybe panned off screen? I can't figure out how to get it back.
I tried to re-create it a number of times, but no luck.
what's happen if you unlock the patch ? do you see something ?
if you can share the patch i'll take a look
skraninger
Here is a freshly created patch (uploaded SynthMaster2.pat). The Synthmaster2 plugin window will show and the synth works.
Just can't see anything in the patch;
http://www.sensomusic.com/forums/upload ... aster2.pat
ok, so i didn't understand first
can you select the bypass or the show button, then click on the find in patch button on the contextual menu on the left
will solve the issue
skraninger
Clicking the bypass button then "find in patch" still showed a blank patching screen.
I am using Usine 32 bit v2.0.081e.
Delete and re-create patch, same process, patch is still blank.
Same thing on multiple computers.
I think there is a "demo" version of Synthmaster2 that you could use to duplicate this.
At one point I had Arturia Analog Lab do something similar. I believe after an update it started to show the plugin editor. I could access the plugin, but there was nothing when I looked in the edit window
Have you try the last version ( 082a) ?
skraninger
It looks like updating to 2.0.082a solved the problem on a PC. Created a new patch and it showed up.
was weird, but good news !
Users browsing this forum: No registered users and 108 guests
